ETM ir MAF problemos 1999-2001m benzininems volvo
ZRimas
Klubo Prezidentas
Pranešimai: 3602
Užsiregistravo: 2008 Spa 17
Auto: XC60 3.0 T6 Premier '16 AT AWD
Susisiekti:
Standartinė ZRimas »
Kadangi problema gali buti aktuali daug kam, o tiek Spliteriui, tiek man siandien teko susidurti su ta pacia problema pas Sava850 jo s60 My2001, permetu MadeInJapan (cia toks zmogaus nick'as http://www.matthewsvolvosite.com" onclick="window.open(this.href);return false; forume) pasisakyma tame paciame forume, o konkreciai cia:SIGNS OF A FAILING ETM AND ITS RELATION TO THE MAF SENSOR
Pateikiu originalu teksta:
1999s70 (George) over on Swedespeed posted the following which I hope you will find highly informative and helpful:
As one who is on his 5th Electronic Throttle Module (ETM) and 4th Mass Air Flow Sensor (MAF), I’d like to write of my experience with these, in particular noting the symptoms of their impending failure (so that you don’t suddenly find yourself with a stalling car as an 18-wheeler barrels down on you from behind), and also telling you how to replace the MAF yourself
Su pagrabu,
Volvo ETM, prietaisų skydelių, ABS blokų ir kitos Volvo elektronikos remontas, diagnostika, programavimas, europinimas ir kt. --> Tel. 86I47I437 http://www.FixVolvoETM.eu
Temoje atsakymų - 4
