Volvo S40 (2000m 1,6) Pultelio programavimas
lariukass
Pranešimai: 3
Užsiregistravo: 2011 Rgs 29
Auto: Volvo s40 T4
Miestas: UK
Standartinė lariukass »
Sveiki , turiu beda nz kaip uzprogramuoti volvo pulteli , nusipirkau pulta bet nz kaip ji aktivuoti gal kas galit padeti , cia angliukai parase bet man neveikia :
Sit in the driver's seat of your 2000 Volvo S40. Close all of the vehicle's doors and press the "Lock" button on the control panel of the driver's side door.
Insert your key into the Volvo's ignition cylinder and quickly remove it. Continue inserting and removing the key at a steady pace until the vehicle's hazard lights flash.
3Reinsert the key into the ignition cylinder and turn it to the "On" position; do not crank the engine.Press the "Lock" button on the keyless remote that you are programming to your 2000 Volvo S40. The vehicle's hazard lights will flash if the programming process is successful. To program a second remote to your car, press the "Lock" button on the second remote. The hazard lights will flash again to i…login , kad matyti kitus pranešimus
Paskutinį kartą redagavo lariukass 2011 Spa 17, redaguota 1 kartą(us).
Temoje atsakymų - 6
