sveiki gal kas esate gamine deze kolonelei , ir galit padet kokio litrazo reikia padaryt deze tokiai koloneliai, su programa nelabai ten iseina surasyt wiska
JBL GT4-12
Subwoofer Size 12"
Peak Power Handling 1000 watts
RMS Power Handling 250 watts
Voice Coil(s) Single
Impedance (Per Voice Coil) 4 ohms
Frequency Response 23 - 450 Hz
Sensitivity 93 dB
Xmax (millimeters) N/A
Woofer Composition Polypropylene
Woofer Surround Rubber
Recommended Enclosure Specifications
Top-Mount Depth 6.25"
Cutout Diameter 11.14"
gal kas gali padeti del zemuju dazniu koloneles dezes
Lawrynas850
- Pranešimai: 156
- Užsiregistravo: 2011 Kov 16
- Auto: Volvo 850
- Miestas: Joniškis
