2006 S60 keičiame galinę spyruoklę
GintasVK
Administratorius
Pranešimai: 510
Užsiregistravo: 2008 Spa 16
Auto: XC60 (740,850,V70,V50)
Miestas: Dresden
Standartinė GintasVK »
2006 Volvo S60
Rear Spring Installation
This is a log of my experience replacing rear springs on my vehicle and it is not a tutorial or service manual procedure.
General tools used:
◦15mm and 18mm combination wrenches
◦15mm, 18mm, and 19mm sockets
◦3" and 6" socket extensions
◦T40 Torx bit and wrench/holder
◦Diagonal wire cutter
◦Internal spring compressor
◦Floor and/or scissors jack(s)
Paveikslėlis
Put the back of the car up on jack stands and remove the wheels.
Paveikslėlis
Remove the trunk floor and side liner to expose the top shock bolt under the foam pad.
Hold the shock stud with a T40 torx bit to keep it from turning while removing the 18mm nut.
Paveikslėlis
Remove the sway bar nuts using the T40 torx bit to hold the stud. Remove the sway bar link and set aside.
Paveikslėlis
Loosen the 15mm bolt holding the leading control arm to the hub knuckle.
It's OK if the bolt does not come all the way …login , kad matyti kitus pranešimus
